Make sound sync with animation!!
COW Forums : Adobe Flash
Annietron
on Dec 28, 2006 at 7:11:19 am
How can i do this?
I always put mp3 inside of a movie clip, but music dosent match with frames.....and also, when i go to fullscreen, it gets worse!!!
Is there something i need to know?
Sher Ali
Re: Make sound sync with animation!!
on Dec 28, 2006 at 7:55:04 am
My experience of using .mp3 is that flash always add one or two frames at the start of the .mp3 sound inserted in a layer. But this is not the case with the .wav files. Try using .wav instead of .mp3 file and feel the difference.
Sher Ali
http://www.webeyestudio.com
Annietron
on Dec 28, 2006 at 5:12:35 pm
Interesting!! I have seen those pucca swf and the sound sync is just great!
I'll try .wav, thanx man, happy holidays
lajoiet
on Jan 3, 2007 at 8:06:01 pm
Also, if you're dealing with sound on the timeline, be sure that your sound is set to stream and not event, because if you set it to stream it will keep the timeline in sync with the sound (dropping frames if neccessary based on the user's system, but that's better than being off sync.
Annietron
on Jan 4, 2007 at 9:37:10 am
stream right? Got it, Would i keep my sound quality if I choose stream?
Thanx a lot!
lajoiet
on Jan 4, 2007 at 5:30:30 pm
Shouldn't affect your sound quality in the least.
