After Effects Growing Vectors to Flash Animation? (see sample)
COW Forums : Adobe Flash
naugamonster
on Dec 27, 2006 at 9:58:36 pm
I am trying to get an animation from AE into Flash, but at small filesize. The animation is of growing vectors (using the write-on technique with masks and reveal original image). The animation I'm getting has several issues:
http://www40.pair.com/digerati/anim/Background3R.htm
1) quality doesn't look like vectors (notice antialiasing)
2) filesize is 3.9 MB (ouch!)
3) imports into Flash as SWF with BMPs (uh oh)
= all unusable.
Export out of AE settings:
Ignore unsupported features, no audio, no options. No rasterization, yes?
I'm obviously missing something (or quite a few things) in this process to make it work correctly. In the end, I need a fast-loading, growing vector animation that is small in filesize, importable into Flash.
Help?
Thanks much!
RobotHero
Re: After Effects Growing Vectors to Flash Animation? (see sample)
on Jan 3, 2007 at 12:56:56 am
I did a test, and Write-on seems to count as "unsupported." So from your description of what you're doing, you should be outputting an un-animated clip.
