FLV not progressively downloading?!?
COW Forums : Adobe Flash
enueism
on Dec 20, 2006 at 8:05:21 pm
so here's the deal
i have 8 flvs...
all videos were edited with final cut pro...exported to deinterlaced quicktime video with the same settings...
batched with the same settings in Sorenson Squeeze 4.5
5 of the 8 videos work fine...
3 of them don't actually progressively download...they just sit there till the whole file is transferred then start playing normally...
the actionscript seems fine..everything works fine locally...
I watched what happens with safari's Activity montior, and it seems that the problematic files don't return the filesize information
basically safari just hangs and says 0 bytes of ? till i the file buffers...
when i actually test to see if i can access the flv directly, the ones that work return as a text file...which is expected
the ones that don't work, don't even do that....
has anyone ever encountered this before?...
thanks...
