How to make the video stay for 5 sec and loop?
COW Forums : Adobe Flash
dotan
on Nov 26, 2006 at 3:06:10 pm
I have this banner i made for a web site its an animation of a text animate in and then stop
i want the text to animate in stay for 5 sec and then loop again
im new in flash can you please describe what i need to write in flash?
thanx
lajoiet
Re: How to make the video stay for 5 sec and loop?
on Nov 26, 2006 at 11:24:11 pm
How are you doing the text animation? If it's all done on the timeline, just add 5 seconds of frames at the end.
dotan
on Nov 27, 2006 at 1:01:58 pm
The animation is done in AE i imported the swf into flash
and now i want it to play stop at the last frame for 5 seconds and loop again
RobotHero
on Dec 1, 2006 at 6:12:01 am
Make a blank movie clip, 5 seconds long.
Associate this with your existing clip:
if (this._currentframe==this._totalframes){
fiveseconds.play();
And put this on your five second clip:
firstmovieclip.play();
enueism
on Dec 21, 2006 at 4:34:46 am
use set interval..it's a lot cleaner..no extra movieclips...
first frame of your movie...write a function ..try this..
function loopMe():Void{
gotoAndPlay(1);
clearInterval(looper);
the last frame of your movie...where you want it to pause...try this..
stop();
var looper = setInterval(loopMe,5000);
the 5000 is the time in milliseconds...it can be adjusted for whatever interval you want...
basically you're just telling it to chill out for however long, then call a play function...clearing the interval till the next time it hits the end...
there's ways to make it loop a specified number of times but this should work for what you're asking...
