anamorphic movies in flash!
COW Forums : Adobe Flash
firewireflow
on Nov 21, 2006 at 8:52:41 pm
hi ... does anybody got experience in integrating anamorphic vidos into flash? how should i give the footage to the flash designer?
any help is very appreciated!
thanks a lot!
florian
Matt Klundt
Re: anamorphic movies in flash!
on Nov 21, 2006 at 10:58:23 pm
I find self-contained Quicktime files to be the easiest to encode into Flash Videos. You needn't worry about the aspect ratio, Flash can handle it. I would make sure your designer is aware of what the correct ratio should be, although a good designer should be able to know from looking at your source material.
Matt
http://www.mcquillendesign.com
http://www.mattfoxgames.com
firewireflow
on Nov 21, 2006 at 11:50:23 pm
thank you very much!
