Delay playback of Prgressive .FLV
COW Forums : Adobe Flash
Terry Hahin
on Sep 18, 2006 at 6:41:39 pm
I am a newbie and apologize if this question is obvious.
I have set up a site with external progressive download flv movies. They look good, and work well, except they start playing before the buffer is far enough to play. The result is a choppy video for 2 seconds, then wait for the download to catch up. I have noticed this with many sites I view in general and have always thought it to be a problem.
Is there a way to not have the progressive flv play right away. Can you set it to wait till, for example, a certain percentage of the file has been cached?
Or is the only to this problem to lower the data rate per second?
Thanks in advance for any help,
Re: Delay playback of Prgressive .FLV
on Sep 19, 2006 at 12:07:42 am
If you're using the NetStream method of playing the video just set the buffer time for the NetStream to a greater length (IIRC the default is .1 second which is hardly anything). Try this to set the buffer to 10 seconds (assuming "ns" is the name of your NetStream Object):
If you're using the FLV Playback Component, it would be very similar, using the instance name of your component:
my_FLVPlybk.bufferTime = 8;
I'm filling a need. Without me there would be no bad examples.
© 2018 All Rights Reserved
