Publish XML Tree for ns Video
COW Forums : Adobe Flash
jhunyadi
on Sep 5, 2006 at 6:17:38 pm
Hi - many thanks to Lee and Todd for the start...
I've been looking for answers to posts about how to get xml to work once published, but I haven't seen a response. So here's the situation:
Created "tree.xml" with this code //
var xml:XML = new XML();
xml.ignoreWhite = true;
xml.onLoad = function() {
theTree.dataProvider = this.firstChild;
//FIRST PLAY
ns.play(theTree.getItemAt(0).attributes.url);
theTree.selectedIndex = 0;
xml.load("tree.xml"); //or xml.load("http://www. --- .com/mediaplayer/tree.xml");
Relative and absolute paths for the tree both seem to work in Publish Preview. The tree populates and the videos play. Then I publish and upload everything to the server, and the swf is fine, but the tree component is empty. Is there an xml trick I have missed? Something on the server side? Or possibly a header on the xml file?
Joshua
jhunyadi
Re: Publish XML Tree for ns Video
on Sep 8, 2006 at 3:24:38 pm
check it out... it is for a local school system... I ftp uploaded on the back of our radio station site for testing.
I think the problem is with the tree component itself, not the xml.
Is there a checklist to use when utilizing a component? Like do I have to select "export for runtime sharing"?
See anything wrong with the swf or xml?
http://www.913thesummit.com/josh/apsMediaPlayer.html
http://www.913thesummit.com/josh/tree.xml
I'm just a video guy trying to help a non-flash web developer- I use flash just for animations.
Any comments/suggestions would be appreciated.
