dissolves
COW Forums : Adobe Flash
grinner
dissolves
on Aug 20, 2006 at 8:55:18 pm
How do I add a dissolve to an imported jpg? Just trying to build a slide show.
Also, how can I increase the quality of animated scales, position and reposition? Every time I create a smooth animation, the result is all aliased.
thanks in advance for any tips for a newb.
Matt Klundt
Re: dissolves
on Aug 21, 2006 at 4:34:58 pm
There is currently no way to anti-alias the movement of bitmaps in Flash. As for dissolves you can script them with the _alpha property if you are so inclined, or you can use motion tweens for the alpha property. You can affect the alpha on the stage by click on a MovieClip, then choosing alpha from the Color dropdown menu in the properties tab.
Matt
http://www.mcquillendesign.com
http://www.mattfoxgames.com
grinner
Re: dissolves
on Aug 22, 2006 at 9:07:51 pm
many thanks, my friend.
