overlapping sound
COW Forums : Adobe Flash
Gustav
overlapping sound
on Aug 5, 2006 at 2:35:42 pm
hi all!
i have made buttons which play a loop each, but whilst one is playing, if you press another, to change the loop, the new one plays over the old one, which sounds horrible obviuosly,
is there a way that i can fix this, bearing in mind i have no clue about scripting?
thanks!
Gus
Sher Ali
Re: overlapping sound
on Aug 8, 2006 at 4:43:11 am
before you play another loop, call the stopAllSounds() method of Sound class,
and this will solve the problem.
Sher Ali
http://www.webeyestudio.com
Gustav
on Aug 12, 2006 at 12:51:57 pm
I tried applying the stop all sounds to the button, but when u press the button it plays a little clip and then cuts the sound, instead of cutting the sound before it plays the new loop.
is there any way i can make it stop all the sounds before it plays the loop?
