loaded flvs inside loaded swfs
COW Forums : Adobe Flash
on Aug 3, 2006 at 5:57:28 pm
I've been trying all morning to figure this out;
I have a SWF(shell) that I am loading other SWFs(subMovies) into.
My subMovies will be having FLVs loaded into them. I get the FLV to load into the subMovie and play just fine using the following code:
var nc:NetConnection = new NetConnection();
var ns:NetStream = new NetStream(nc);
They work great when I test them out.
When I load a subMovie into shell though, the video does not play. If anyone can shed some light on to why I'm having this problem it would be an immense help!
Matt Klundt
Re: loaded flvs inside loaded swfs
on Aug 4, 2006 at 10:19:38 pm
The path for your videos will need to be relative to your shell swf file, or the html page that contains the shell swf file.
Does that help?
on Aug 7, 2006 at 4:06:36 pm
Hi Matt,
Thanks for the reply :) I figured that out. That's pretty annoying. Hopefully they'll fix that. I ran into other hook ups though so we may now be embedding all our video :(
Hopefully I can use the netstream and flvs for another project though.
© 2018 All Rights Reserved
