FORUMS: list search recent posts unregisters cue points?
COW Forums : Adobe Flash
mprzybylski unregisters cue points?
on Jul 26, 2006 at 3:29:00 pm
Hello all,
I am streaming some FLV files from a streaming server. What happens is that I'm i have an onCuePoint event that stops the stream, and it works fine. As soon as the stream hits a cue point, it pauses and waits for the user to click play or a proceed button on screen. However, I also have "chapter skip" buttons that go to the next/previous cue point. Once i start using these buttons, any subsequent cue point after i have skipped to a chapter (a cue point marker in simpler terms) does not register and no longer pauses the stream.
The code on the next/previous buttons is simple. The next button code is below:
// move to the next chapter of the stream
private function seekToNextChapter():Void
//this.previous_btn.enabled = true;
var curTime:Number = this.currentStream.time;
var curVid:Object = this._currVidObj;
var totalCues:Number = curVid.cues.length;
var newTime:Number;
for (var i:Number = 0; i < totalCues; i++)
if (curTime < curVid.cues[i].cueTime)
newTime = curVid.cues[i].cueTime;
//if (i == (totalCues - 1)) this.next_btn.enabled = false;
the code works fine, just "unregisters" all subsequent onCuePoint events, like, i can't even trace it out when i hit a cue point that it's running the onCuePoint event of the netStream.
the seekTo function is also simple:
// moves to the selected position in the stream
private function seekTo($t:Number):Void
has anyone ever ran into this problem or knows how to fix it?
Thanks in advance guys!
- Matt
© 2018 All Rights Reserved
