audio problem
COW Forums : Adobe Flash
philla542
audio problem
on Jul 23, 2006 at 2:50:48 am
Hello, I am a beginner at flashpro. I am trying to import music and sounds into my animation, but when i do, it doesnt show up in the import audio screen which means it is probably not the right format. Please tell me what i should do. Thank you in advance.
phil
lajoiet
Re: audio problem
on Jul 23, 2006 at 10:49:56 am
What is the format of the audio you're trying to import?
I've used WAVs, AIFFs, and MP3 files and never had a problem. One of the things to keep in mind is Flash can only correctly play files that have a sample rate of 44.1kHz. Other sampling rates will import and play, but they will play at incorrect speeds. But I don't think that's your problem.
>Todd
_____________________________________
I'm filling a need. Without me there would be no bad examples.
philla542
Re: audio problem
on Jul 23, 2006 at 6:03:06 pm
Thank you
phil
