Changing the forwarding URL outside of Flash
COW Forums : Adobe Flash
CowRob
on Jun 30, 2006 at 8:47:23 pm
I have a client that would like to be able to quickly edit a .swf file to change the forwarding URL. What they
thumbslinger
Re: Changing the forwarding URL outside of Flash
on Jun 30, 2006 at 8:56:04 pm
Possibly passing the new url via a variable in the html instead and setting up the fla to receive that.
See this article and particularly the section on skipping repetive animations:
http://www.thefwa.com/articles/hybrid1105.html
lajoiet
on Jun 30, 2006 at 10:18:21 pm
Or set up the Flash file to pull the links from an XML file and parse them into an array, then have the link buttons pull their destination url from the correct index number of the array. Then they just have to use a text editor to change the links in the XML file which can be set up to be pretty obvious what to change.
>Todd
_____________________________________
I'm filling a need. Without me there would be no bad examples.
CowRob
on Jul 5, 2006 at 5:28:28 am
Thanks guys . . . think I found another solution in a book called Flash Hacks by Sham Bagnal.
There's an application called URL Action Editor
http://buraks.com/uae
That appears to do exactly what I'm looking to do, and does it easily enough that a client could do it themselves. As I'm an animator and not an XML guy, I'm afraid the solution needs to be pretty basic. And this app seems to fit the bill.
The other option since I'm just changing one URL, is to see if I can oepn the .swf in a text editor and change it there.
Thanks again,
Rob
