attaching .flv behavior to buttons
COW Forums : Adobe Flash
A.R. Simone
on Jun 27, 2006 at 10:10:09 pm
I have an instance of a flv player on my stage. I would like to create a number of buttons that will load different .flv videos into the player. I an not sure how to utilize the attach video behavior to the buttons or even if that is the correct way to proceed. I am new to flash so any help will be much appreciated.
Thank you,
Re: attaching .flv behavior to buttons
on Jun 28, 2006 at 3:39:28 am
I'm not exactly sure how to do it, but if you are just beginning with flash video i'd suggest checking out - it's really good for understand some of the basics of handling video
on Jun 29, 2006 at 11:23:45 pm
Take a look at this:
var myVideo:FLVPlayback;
myVideo.autoPlay = true;
myVideo.autoRewind = false; = false; //also can use parameters area
myVideo.contentPath="video/otherMovie.flv";//this is where various flv can be instructed to load
with (myVideo){
playPauseButton = vcPlayPause; //setting methods = to instance name of graphic/con to use.
stopButton = vcStop;
seekBar = vcSeek;
backButton = vcRew;
forwardButton = vcFFwd;
The 'vc' is short for Video Control and represents the name of the instance name of the graphic I was using for a particular custom controller (play, rewind etc)
So, on a button you might just say something like:
on.ButtonName.Release = function() {
on Jul 7, 2006 at 6:37:34 pm
I haven't seen any behaviors that look like this. I am using Flash 8 pro.
Is this something that is adjusted in the components (parameters) windows or is it an action script?
new to flash joe
© 2018 All Rights Reserved
