A few FLV questions
COW Forums : Adobe Flash
Mogamblin
A few FLV questions
on Jun 1, 2006 at 8:28:57 am
Hello Everybody,
I have 2 questions regarding the flv playback behavior of flash 8 pro
Is there a max resolution that a flv file can have?
Currently I am working with a flv file which has a resolution of 3800*240, and I might need it even wider,
are there any limits?
Secondly, when I animate the flv playback window in my timeline to move from the lets say x=10 to x=30, then flash doesn't show any video at all.
I have tried this with "normal" resolution flv files as well but it didn't work.
I used a simple tween to move the window.
with kind regards
Mogamblin
Matt Klundt
Re: A few FLV questions
on Jun 1, 2006 at 5:50:32 pm
I haven't tested, but I am know Flash will not allow any MovieClip or Image to exceed 2880 pixels (wide or tall). I will make a wild guess that this would hold true for flv files as well.
What kind of tween are you attempting to use? A Motion Tween or a Shape Tween? A component video player or a custom built video player?
Matt
http://www.mcquillendesign.com
http://www.mattfoxgames.com
Mogamblin
on Jun 2, 2006 at 12:46:31 pm
Hey Matt,
I just try to do a simple motion tween, with the standard video player component without any skin.
Later on, the user should be able to "move" the video clip with the position of his mouse courser.
So, if the courser is more to the left of the screen the videoclip moves faster to the left.
I don't know if that is of use for you but I create my flv's with after effects 6.5
with kind regards
Mogamblin
Matt Klundt
on Jun 2, 2006 at 2:12:47 pm
Does the video or "normal size video" show up when you do no movements at all?
Matt
