It is possible to play video @ full screen smoothly in a standalone flash .exe file?
COW Forums : Adobe Flash
duncan shinn
on May 4, 2006 at 4:35:24 pm
It is possible to play @ video full screen smoothly in a standalone flash .exe file?
I've imported the video at different bitrates and when i play the .exe its still unable to play the video and audio smoothly at full screen. I've also tried it on a few different spec PCs but still having a problem.
Are there any neat tricks to fix this?
Matt Klundt
Re: It is possible to play video @ full screen smoothly in a standalone flash .exe file?
on May 5, 2006 at 2:21:52 pm
I don't believe that is something Flash is currently designed to handle. You would probably have better luck using Director for full screen video .exe's instead. I myself don't like Director, but it is a better program for fullscreen standalone projects.
What you could try (staying with Flash) though, would be reducing the screen resolution of the monitor to a lower setting, like 800x600. This can't be counted on if you are mailing it out to clients though.
Matt
http://www.mcquillendesign.com
http://www.mattfoxgames.com
duncan shinn
on May 5, 2006 at 3:15:22 pm
ok cool thanks,
just a quickie...
if i was to use director instead would it still be able to handle video with an alpha channel?
cheers
Matt Klundt
on May 5, 2006 at 3:52:40 pm
I don't know., you could try the Director forum though.
Matt
