combine multie swf into one
COW Forums : Adobe Flash
Todd Morgan
on Apr 21, 2006 at 5:34:25 pm
Hi all,
How would I take several swf files and make one complete file? I have created several banners for a website i am designing (learning as I go) and need to make one swf out of them all so they all play back to back.
Todd
Todd Morgan
Creative Director
Freelance F/X Inc.
lajoiet
Re: combine multie swf into one
on Apr 21, 2006 at 11:03:04 pm
Well, you could do several things. If you wanted them all in one file, and you are basically using timeline animtation, you can copy all the frames from say the second SWF and paste them in at the end of the timeline of the first SWF, then repeat for the 3rd SWF.
Or you could make a 4th SWF that dynamically loads the original 3 SWF files into it sequentially.
Or you could add code to the end of each SWF that would load the next SWF into _level0, which would replace the current one with the next one at runtime.
>Todd
_____________________________________
I'm filling a need. Without me there would be no bad examples.
Mike_S
on Apr 22, 2006 at 11:10:46 am
That all sounds good.
Another idea might be to build youreself a small Flash promo app / interface, which allows users to browse categories / styles of work, and then launch the ones they fancy, rather than having to watch them in your predetermined order ..?
