Click To Activate And Use This Control
COW Forums : Adobe Flash
Jeff Pelletier
on Apr 18, 2006 at 9:41:44 pm
I am getting this message after i upload videos, and then try to play them. never seen this before. is this a new thing from explorer?
as always, thanks in advnace!
Jeff Pelleiter
jeff.pelletier@mii.com
mii.com
Jeff Pelletier
lajoiet
Re: Click To Activate And Use This Control
on Apr 19, 2006 at 11:03:15 am
Yes, Microsoft IE now requires you to activate all Active X components (the Flash Plugin is one). It's a pain in the a$$, but I think you should only have to do it once. I use Opera myself, so I can't say as I have hit the message.
>Todd
_____________________________________
I'm filling a need. Without me there would be no bad examples.
Jeff Pelletier
on Apr 19, 2006 at 7:30:24 pm
Todd,
Thanks for the reply! I have checked my IE and it is up to date. i am unsure where to go from here.....
jeff
Jeff Pelletier
George Socka
on Apr 21, 2006 at 12:08:27 am
Search for activex activation - a side effect of EOLAS winning its lawsuit against microsoft. There is a solution using Javascript on the macromedia and on the MS websites. This problem will not go away unless MS wins against Eolas.
lajoiet
on Apr 21, 2006 at 10:53:24 am
Also, check out FlashObject which is an open source Java solution that also covers Flash detection.
gregory1975
on Apr 24, 2006 at 7:37:53 pm
The reason for this message is:
http://en.wikipedia.org/wiki/Macromedia_Flash#.22Click_to_activate_and_use_...
The cure for this message is:
http://www.mix-fx.com/flash-prompt.htm
Hope that will be enough help.
Kind regards,
Greg
thumbslinger
Re: Click To Activate...Not 4 FLV's?
on Apr 28, 2006 at 6:16:25 pm
This doesn't seem to be working for FLV's....a black box just appears?
