Dynamic Text within Imported SWF
COW Forums : Adobe Flash
Seth Olson
on Apr 17, 2006 at 7:54:35 pm
I am getting the impression that I cannot define text for dynamic text within an imported SWF. Is this as true as it seems?
NOTE: For visual reference, this project/problem is located on the First Floor:
(The current rough draft has static values and the item list under the main menu does not work.)
I am trying to define text for dynamically created labels from the main document to a secondary, imported swf. "main" MC holds the imported SWF. "imageSign" is a circle shaped clip called from the library. The following line of code is pulled from a complicated function that builds an entire navigation scheme around an invisible button over an image of building blueprints.
_root.main.firstfloor["imageSign"+labelsButtonNumber].listNumber.text = labelsButtonNumber;
When tracing the variable "labelsButtonNumber" or the object
Re: Dynamic Text within Imported SWF
on Apr 20, 2006 at 12:56:17 pm
You never actualy state what the problem is in your post..
I'm assuming that you dont see the text?
Did you make sure that it's embedded in your flash movie?
© 2018 All Rights Reserved
