flash pop up
COW Forums : Adobe Flash
daveyg
flash pop up
on Apr 14, 2006 at 12:16:24 am
i want to have a unscalable pop up.. here is my code:
stop();
this.onEnterFrame = function() {
if (rewind == true) {
prevFrame();
this.onRollOut = this.onReleaseOutside = function() {
rewind = true;
this.onRelease = function() {
getURL(javascript:openNewWindow('http://www.velocityouth.com/amazingrace.htm','thewin','height=366,width=277,toolbar=no,scrollbars=no');
BUT i keep getting this error and my file doesnt work
**Error** Symbol=button, layer=Layer 3, frame=1:Line 14: ')' or ',' expected
Total ActionScript Errors: 1 Reported Errors: 1
Can anyone help me figure this out.
David May
Re: flash pop up
on Apr 17, 2006 at 2:40:46 pm
you have to be aware of what data types you are sending through flash functions, aka as an expression or not. It looks to me that you send this data:
as a string (expression) because of the single quote you have included around this set of charactors. Unless i know the function well i usually look at the reference for that function which usually tells which data types to use. I am not completely familiar with using java script with Flash and get URL but you may try playing with your placement of quotes. my best guess would be:
getURL('javascript:openNewWindow('http://www.velocityouth.com/amazingrace.htm','thewin',height=366,width=277,toolbar=no,scrollbars=no');
aka send that whole statement as an expression to flash, and within the expression, send height, width, ... as variables. Check out some documentation online for java/flash interaction
