Alpha channels in flash 8
COW Forums : Adobe Flash
on Mar 23, 2006 at 7:11:15 pm
Hi I need some help with Alpha channels. I created an animation in 3ds max & rendered it as a QuickTime with alpha. The when I imported it into flash 8 (with the alpha channel) the background is not transparent. It is just a block box with my animation. Can someone please let me know what I might be doing wrong?
Jeremy Lei
Ryan - R2
Re: Alpha channels in flash 8
on Mar 24, 2006 at 8:22:29 pm
I would suggest importing the video into flash and then using the vp6 codec with preserve alpha turned on. This will convert your .mov into a .flv file. This should solve your problem. If you don't have Flash 8 then's more complicated.
© 2018 All Rights Reserved
