Save info in external file
COW Forums : Adobe Flash
Luke Ike
on Mar 22, 2006 at 8:48:44 pm
Is it possible in to have flash save information to an external file? (possibly a text file) If so how would I do it and also how could I have flash "use" or retrieve info in that file?
Sher Ali
Re: Save info in external file
on Mar 23, 2006 at 9:57:30 am
use a server side programming language for that purpose,
for example you can use PHP to write information to a .txt
file and retreive using flash.
create a LoadVars object and then send the data to server using
the send or sendAndLoad method to to send data to be written in
a file using php
hope this helps, otherwise ask i will provide a sample file.
Sher Ali
http://www.webeyestudio.com
