Sound problem
COW Forums : Adobe Flash
Tomer
Sound problem
on Mar 14, 2006 at 10:30:42 am
i'm doing presentation in flash, and in some of the pages i have a small
movie with sound.
The problem is that the sound playing with no connection to the movie.
(like..if i turned to the next page, the sound does'nt stop.)
My question is, where is the sound controlers of the movie...
THANK YOU ALL...
tomer
lajoiet
Re: Sound problem
on Mar 14, 2006 at 2:34:28 pm
If you have your sound on the timeline, rather than controled by actionscript, you probably have the Sync setting set on "Event" which means once the sound is started, it will play until it is complete or loop/repeat the number of times it is set for. If you change the sync to "Stream" the sound should stop if you move to a part of the timeline that it does not exist on. Of course the downside to "Stream" is that if you stop or pause the timeline, the audio will stop or pause also.
If you're controling the sound through actionscript, you just need to tell your sound object to .stop();
>Todd
_____________________________________
I'm filling a need. Without me there would be no bad examples.
Tomer
Re: Sound problem
on Mar 14, 2006 at 7:51:49 pm
Thank you (you're right in the regular Flash Document), but the problem is in the presentation in flash..
When i go to the next page(scene), the sound does'nt stop..
I hope you will know what to do...and thank you again...
tomer
lajoiet
Re: Sound problem
on Mar 15, 2006 at 2:10:23 am
Did you check the properties, and make sure that the Sync setting is set to "Stream"?
>Todd
Tomer
Re: Sound problem
on Mar 15, 2006 at 12:32:00 pm
yes,i try this, it's working on the Flash Document, but i have a problem with the flash slide presentation..
tomer
