How do I keep a streaming flv from playing until user clicks play?
COW Forums : Adobe Flash
honion
on Mar 7, 2006 at 2:58:00 pm
I am trying to get the file to loop a still image that would act as a buffer until the user clicks play, but I don't see how to do it with streaming video, I have tried putting in a preloader but that doesn't work and I have tried adding a stop into the code and that doesn't work. Here is the code I am using. I essentially want to turn off "autoplay"...
var nc:NetConnection = new NetConnection();
nc.connect("rtmpt://flash.maddash.net/flashv/ng");
var ns:NetStream = new NetStream(nc);
ns.setBufferTime(5);
ns.onStatus = function(info) {
if(info.code == "NetStream.Buffer.Full") {
bufferClip._visible = false;
if(info.code == "NetStream.Buffer.Empty") {
bufferClip._visible = true;
theVideo.attachVideo(ns);
ns.play("ng_overview");
pauseButton.onRelease = function() {
ns.pause();
playButton.onRelease = function() {
ns.play();
lajoiet
Re: How do I keep a streaming flv from playing until user clicks play?
on Mar 7, 2006 at 9:00:42 pm
Immediatly after:
put:
ns.pause(true);
Also, your code for the play button is incorrect. The ns.play function is used to attach a video to the netstream object, not for play/pause. To code correctly for separate play and pause buttons it should be like this:
ns.pause(true);
ns.pause(false);
When you use the ns.pause(); function without the true or false parameters it acts like a toggle. So in your code the pause button would both pause and play the video, depending on if it were playing or paused when it was clicked.
>Todd
_____________________________________
I'm filling a need. Without me there would be no bad examples.
