Converting video to flv
COW Forums : Adobe Flash
emmlori
on Feb 21, 2006 at 8:58:50 pm
What is the best way to convert a video to an flv file? My video is in Final Cut so it can be exported in any number of files to begin with. What type of file should I start with for optimal quality? I will also be changing the size, if that matters...
Lori
Elemental Motion Media
http://www.elementalmotionmedia.com
emmlori
Re: Converting video to flv
on Feb 21, 2006 at 9:00:27 pm
p.s. I'm working with Flash 8
Lori
Matt Klundt
on Feb 21, 2006 at 10:59:02 pm
With the Flash 8 Video Encoder, you can export to flv from within Final Cut Pro. It becomes one of your export options after installing Flash 8 Pro, that would be the ideal way to send it out since it will render from the source material.
Matt
http://www.mcquillendesign.com
http://www.mattfoxgames.com
LeeBrimelow
on Feb 22, 2006 at 3:36:44 am
Yes I second that. You want to avoid double-compressing your files. It will add artifacts and quality loss. Straight out from FCP is the ticket. If you have to do it another way try a lossless codec like the QT animation codec
video-flash
on Mar 13, 2006 at 9:36:00 am
You can use Flash Video MX to convert video to flv,
more info on http://www.flash-video-mx.com
