Loading FlashPaper content into Projector
COW Forums : Adobe Flash
lajoiet
on Feb 19, 2006 at 3:34:28 am
Anyone have any experience loading FlashPaper content into an SWF?
I've tried setting up a holder movie clip and loading the FlashPaper SWF into it and loading it onto an empty level, but I have no control over the size of the header controls. I can scale the image up and down, but instead of expanding the page controls, it scales them, which looks horrible.
I'm basically making a projector file with a stage that is 800x600, and I'd like to control the FlashPaper content size in the application so I can start it out at a decent size, but not fill the entire stage with it.
>Todd
_____________________________________
I'm filling a need. Without me there would be no bad examples.
lajoiet
Solution: Loading FlashPaper content into Projector
on Feb 19, 2006 at 4:04:53 am
DOH!!! gotta remember to check more than just the Flash Help File. Apparently you use the same setSize command you would use for components.
Anyone else looking can find it explained here:
http://www.macromedia.com/support/documentation/en/flashpaper/2/flashpaper_...
Page 4 has a prebuilt function for loading the FlashPaper document into a holder and resize it to numbers you feed the function.
>Todd
