problem with XML_Video_playlist
COW Forums : Adobe Flash
Waldek
on Feb 15, 2006 at 6:58:17 pm
Hi.
Can somebody help me to make XML_Video_playlist more user friendly? ;))
I want to start each movie manualy. In this sample each movie start one after another, but what to do to disable this behavior? I'am totaly newbie in Action Script. Please advice.
lajoiet
Re: problem with XML_Video_playlist
on Feb 15, 2006 at 9:28:22 pm
Where did you get the sample you are using? It would help us know what's going on if you gave us a link to look at your FLA or if you could paste your code into your post.
Your issue is exactly the opposite of what most people want to do based on Lee's Video Playlist tutorial. Have you checked that out?
http://www.gotoandlearn.com
Under "Select a Tutorial" look for and click "XML Video Playlist"
Depending on where you got your video player (or if you coded your own based on Lee's tutorials) this may or may not make sense.
>Todd
_____________________________________
I'm filling a need. Without me there would be no bad examples.
Waldek
on Feb 15, 2006 at 10:54:29 pm
Hi and thank you for quick response.
I download a package xml_video_playlist.zip from gotoandlearn.com
What I want to do is a list of short movies to watch from website. I saw Lee tutorial, so I decide to use it. I understand that this is only a general directions what to do.
So, problem number one:
script starting to play first movie from the list as soon as you go there, which is OK because I can put some ad, but after this first movie is end automaticlly loading second movie, and another and another.
problem number two:
I'am totaly newbie in Action Script ;))
What I want is: list with movies
movie1
movie2
movie3
but I don't want to that script loading next movie before user click in title.
Sorry for my english but I'am trying to explain as much as I can
Thank you
lajoiet
on Feb 16, 2006 at 1:25:21 am
Well, if you're using Lee's XML player, there are 2 lines there that say:
ns.play(videoList.getItemAt(0).data);
videoList.selectedItem = 0;
It should be around line 136 of the actionscript, after the "for" loop (for i=0,i
If you delete these 2 lines (or better yet, just comment them out by putting "//" at the beginning of both lines) the player will no longer automatically play the first video once the XML is loaded and will only play a video when the user selects one from the list.
>Todd
Waldek
on Feb 16, 2006 at 2:06:09 pm
I madew mistake to respond to wrong post. Please check below
Waldek
on Feb 16, 2006 at 1:55:14 pm
Thank you very much, but... :)
How to play each movie once? Each movie playing in loop.
Second problem after user going to this page buffering message playing. I know I'am dumb.
I need one more help ;)) I will try to contribute some other info in area where I'am strong.
lajoiet
on Feb 16, 2006 at 4:47:58 pm
to stop the videos from looping remove (or comment out) the following part of the ns.onStatus function ( should be around line 17-19)
if(info.code == "NetStream.Play.Stop") {
ns.seek(0);
I don't understand what you're saying the problem is with the buffer message.
>Todd
Waldek
on Feb 17, 2006 at 12:36:48 am
Thank you for stop solution ;)
If you aren't click to play movie, you can see "buffering video" screen. Should I make any screenshot to put in first frame ?
lajoiet
on Feb 17, 2006 at 1:55:01 am
Hmmm, I might be off on this one cause I don't have time to test it out, but I think in order for you to not see the buffer message when the videos are not playing you will need to change where the ns.onStatus function gets called, and delete it when a video is completed. Take the entire block of code (should be lines 10-20):
ns.onStatus = function(info) {
if(info.code == "NetStream.Buffer.Full") {
bufferClip._visible = false;
if(info.code == "NetStream.Buffer.Empty") {
bufferClip._visible = true;
ns.seek(0);
and put it inside the vidList.change function. Also, remember that you commented out the 3rd if statement. We're going to keep it in, but modify it to delete the ns.onStatus function when the video stops. So now the vidList.change function (line 142 in the original code, it will have moved up about 10 lines if you cut out the ns.onStatus function) should look like this:
vidList.change = function() {
delete ns.onStatus;
ns.play(videoList.getItemAt(videoList.selectedIndex).data);
>Todd
Waldek
on Feb 17, 2006 at 2:20:20 am
working fine but still I see buffering vide when I go first time to this website.
Please check:
http://www.teamdewittracing.com/playlist.html
lajoiet
on Feb 17, 2006 at 3:41:17 am
Did you remove the first ns.onStatus code block (lines 10-20)?
>Todd
Waldek
on Feb 17, 2006 at 11:38:11 am
yes, I did
