updating project to Flash 8
COW Forums : Adobe Flash
Jeff Penano
on Feb 7, 2006 at 4:01:06 pm
I'm trying to update a project from Flash 7 to Flash 8. Thing is I didn't develop the back-end of this thing and slowly trying to figure it out. The project works fine in Flash 7 but I get a few errors when publishing to Flash 8. When I publish I get this error:
**Error** /as/sequence.as: Line 2: ']' expected
var prevBar = this[highlightPrefix add (cue-1)];
**Error** /as/sequence.as: Line 3: ']' expected
var highlightBar = this[highlightPrefix add cue];
--------- The external .as file is as follows: -----------------
function highlighter(cue:Number, highlightPrefix, imagePrefix) {
var prevImg = this[imagePrefix add (cue -1)];
var highlightImg = this[imagePrefix add (cue)];
if(highlightBar.lit != true) {
prevBar._alpha = 0;
prevImg._alpha = 0;
highlightBar._alpha = 70;
highlightImg._alpha = 70;
highlightBar.lit = true;
} else {
highlightBar._alpha = 0;
highlightImg._alpha = 0;
highlightBar.lit = false;
function imageCue(cue:Number, imageArray:Array) {
if (stopPressed != true) {
loadImage(_global.path + "images/" + imageArray[cue-1]);
} else {
loadImage(_global.path + "images/" + imageArray[0]);
If push comes to shove I'll just keep developing this project in Flash 7 but I'd really like to upgrade it to 8.
LeeBrimelow
Re: updating project to Flash 8
on Feb 7, 2006 at 11:22:11 pm
I'm not understanding this line of code...
what is the add for?
LeeBrimelow
on Feb 7, 2006 at 11:23:01 pm
If you are trying to concatenate something together you need to use the "+" sign instead of add
Jeff Penano
on Feb 8, 2006 at 3:41:38 pm
Yeah, changing "add" to "+" seemed to work. Much thanks!
--Jeff Penano
