Changing Text Color in Text Scroller
COW Forums : Adobe Flash
sally
on Feb 2, 2006 at 6:33:14 pm
I'm using Flash Prof. 8.
How can I style a textarea component and have html set to true?
When I change the html setting to TRUE in the parameter, the text is formatted correctly (ie. with HTML line breaks.) But my styling is lost! My goal is to change the background color and text color. For some reason the text color won't change unless I set "HTML" to false.
There must be some script I am missing here.
Thank you for any assistance.
Matt Klundt
Re: Changing Text Color in Text Scroller
on Feb 2, 2006 at 7:58:05 pm
One problem I've learned with TextFields is that you always have to call setTextFormat() everytime after you change the text value of a dynamic text field. I don't know if this is true for components as well, but it is worth a try.
Matt
http://www.mcquillendesign.com
http://www.mattfoxgames.com
