Cue Point Question.
COW Forums : Adobe Flash
downtownguy
Cue Point Question.
on Jan 31, 2006 at 4:38:20 am
I was wondering if there was any way of using cue points with the following method of playing an FLV video?
var nc:NetConnection = new NetConnection();
nc.connect(null);
var ns:NetStream = new NetStream(nc);
video.attachVideo(ns);
ns.play("video.flv");
lajoiet
Re: Cue Point Question.
on Jan 31, 2006 at 2:23:54 pm
You should be able to use:
ns.onCuePoint = function(infoObject:Object) {
trace("onCuePoint:");// not needed, but it will tell you the parameters of your cue point
//plus whatever other code you want to happen when a CuePoint is reached
If you do a search in the help file for flash for "onCuePoint" you can read the help file for more information.
downtownguy
on Jan 31, 2006 at 11:03:19 pm
As always, thanks a bunch! :)
I will play around with it.
lajoiet
on Jan 31, 2006 at 11:27:34 pm
Doh!!!!
trace("onCuePoint");
isn't going to give you the parameters of your cuepoint, it's just going to trace "onCuePoint".
to get the information in the cuePoint object you need to run a batch of code like this (from Flash's Help File):
for (var propName:String in infoObject) {
if (propName != "parameters")
trace(propName + " = " + infoObject[propName]);
else
trace("parameters =");
if (infoObject.parameters != undefined) {
for (var paramName:String in infoObject.parameters)
trace(" " + paramName + ": " + infoObject.parameters[paramName]);
else
trace("undefined");
downtownguy
on Feb 3, 2006 at 6:02:25 am
Thanks again so much for your help! :) Here's what I came up with, thanks to your help, and the help of a few other people on the WWW.
FIrst, I used Flash 8 Professional to embed my event cue points at specific times. Then, I used the following ActionScript:
var myCueNextIndex:Number = 0;
var myCue:Array = new Array();
myCue.push(intro);
myCue.push(clarity);
myCue.push(regain);
myCue.push(bottleTwo);
myCue.push(brainTest);
// EVENT HANDLER: onCuePoint
ns.onCuePoint = function(eventObj:Object)
var myCueNext:MovieClip = myCue [ myCueNextIndex ];
myCueNext.play();
myCueNextIndex++;
