Flash Animation and video
COW Forums : Adobe Flash
on Jan 29, 2006 at 10:26:46 pm
Hello im pritty new with flash but can work in it pritty well anyway with adding streaming media in it and so forth. anyway now i would like the flash animation to be halted and start after the streaming FLV video is ended.
i have the flv streaming on one layer and then after 32sek when the video is done i would like the other layer to be activated and show a text, how is this possible? is there somewhere i can set a time intervall to where it should be started?
thank you
Re: Flash Animation and video
on Jan 30, 2006 at 1:38:49 am
Assuming that you have your video streaming onto frame 1 (and having a stop action on frame 1 so it stays there while the video is streaming)and your text appears on frame 2, and that your netstream object is named "ns", you could just add the following code into the frame 1 actionscript where you have your netstream set up and playing:
ns.onStatus = function(info) {
if (info.code == "NetStream.Play.Stop") {
© 2018 All Rights Reserved
