loadMovie ???
COW Forums : Adobe Flash
Michael Wilfong
loadMovie ???
on Jan 17, 2006 at 5:31:00 pm
Hello...
I'm trying to load a swf file into a swf file...when I use the following code it IS loading the movie but I can't see anything??? why?
this.onEnterFrame = function() {
loadMovie("AttitudeScroll.swf","Attitude");
Can anyone tell just by what is here?
Thanks in advance.
M
Matt Klundt
Re: loadMovie ???
on Jan 17, 2006 at 6:00:46 pm
Part of the problem is that you are (re)loading the movie every time a new frame is rendered (so, 12 or maybe 24 times per second?). Why not just use the loadMovie line on a frame instead of assigning it to a MovieClip?
this.loadMovie("AttitudeScroll.swf","Attitude");
Matt
http://www.mcquillendesign.com
http://www.mattfoxgames.com
Michael Wilfong
Re: loadMovie ???
on Jan 17, 2006 at 8:11:37 pm
Is there a reason why I can't 'see' or 'interact' with the external .swf file when it is loaded?
Thanks for the help, I really appreciate it.
M.
Matt Klundt
Re: loadMovie ???
on Jan 17, 2006 at 8:50:15 pm
It is one of two possibilities. First it could be that you have not specified an _x or _y value for the clip, in which case it won't be displayed. Or secondly, your path to the file you want to load has an error. Try being case sensitive, use %20 instead of spaces, or try using an absolute URL to the intended file. Also try the debugger and/or trace functions to see if the clip is in fact there.
Matt
Michael Wilfong
Re: loadMovie ???
on Jan 17, 2006 at 8:58:13 pm
I'm Sorry, I wasn't very clear...I can see part of the external .swf file...it is a scrolling text field using a mask...
I can see the scroller but not the content(text) inside the scroll area...does that make sense to you?
when I load it into a "level" i can see everything but when i load it into an empty movieclip I see just the scroller...
I can email you the files if you feel like helping out an amatuer...
Thanks again for your help.
Michael.
Matt Klundt
Re: loadMovie ???
on Jan 17, 2006 at 9:10:25 pm
You should look through past posts as this has been covered many times. The problem is the mask not the loadMovie command. Try this one:
http://forums.creativecow.net/cgi-bin/new_read_post.cgi?univpostid=856761&f...
Matt
