stopDrag is not stop drag?
COW Forums : Adobe Flash
Renderwise
on Jan 12, 2006 at 7:27:23 pm
Hi!
Is it possible to turn off the drag-function for a movieclip? After the movieclip is postioned at the right place I want the drag-function to be turned of. And all have to work in the same frame(else, it would be easy to just move the playhead and "fake")As it is now one can press and drag the clip again after it have been droped and placed and stopDrag have been executed, I am using the script below, the drag and drop works as it should. But how do I change the code to make it work as wanted?
(Flash 8 Pro, OSX 10.4, G5 dual 2,5, 2gb RAM)
circle_mc.onPress = function(){
this.startDrag();
circle_mc.onRelease = circle_mc.onReleaseOutside = function(){
this.stopDrag();
if (eval(this._droptarget) == circleBig_mc) {
status_mc.gotoAndPlay ("correct");
} else {
this._x = 112;
this._y = 316;
Matt Klundt
Re: stopDrag is not stop drag?
on Jan 12, 2006 at 8:31:44 pm
Add circle_mc.onPress = null; to the code like so:
this.startDrag();
this.stopDrag();
} else {
this._x = 112;
this._y = 316;
Matt
http://www.mcquillendesign.com
http://www.mattfoxgames.com
Renderwise
on Jan 12, 2006 at 9:10:23 pm
Thanks! It works! But I forgot to ask if one also can turn off the possibility to click(press, release) when the movieclip have been droped?
