Using the Tween Class in Flash 8
COW Forums : Adobe Flash
Rob Stemm
on Dec 29, 2005 at 2:20:03 am
I have some questions about using the tween class in flash 8. Basically I've set up a box movie clip and two combo boxes so the user can alter the properties of the tweening. This is based off of Lee Brimlow's tweening exercise on http://www.gotoandlearn.com
my problem is that the tween class doesn't recognize a string variable that is being set by two combo boxes. (myObject_list and myEasing_list) When the user releases myButton the String variable finalEasing has the string (myObject_list.value+"."+myEasing_list.value) or lets say Strong.easeIn in one case. When I trace this the everything looks correct, but the box that is supposed to tween doesn't react to the new tween properties.
do I need to do an eval(finalEasing) to get the tween to understand func parameter to be Strong.easeIn
Any help would be much appreciated
Rob
Below is my Actionscript
import mx.transitions.Tween;
import mx.transitions.easing.*;
var finalEasing:String;
myButton.onRelease = function () {
finalEasing = (myObject_list.value+"."+myEasing_list.value);
trace ("final Easing String = "+finalEasing);
if (box._xscale < (150)) {
grow(box);
} else {
shrink(box);
function grow(who) {
var tw:Tween = new Tween(who,"_xscale",finalEasing,100,400,1,true);
var tw2:Tween = new Tween(who,"_yscale",finalEasing,100,400,1,true);
function shrink(who) {
var tw:Tween = new Tween(who,"_xscale",finalEasing,400,100,1,true);
var tw2:Tween = new Tween(who,"_yscale",finalEasing,400,100,1,true);
