Animate Transparency in Swift 3D?
COW Forums : Adobe Flash
Eric Klassen
on Dec 21, 2005 at 6:59:18 pm
In Swift 3D, can transparency be animated to an object like Opacity in After Effects? It seems I cannot locate or bring Transparency into the timeline in Swift 3D. If this is possible, how do I do this?
Re: Animate Transparency in Swift 3D?
on Dec 22, 2005 at 7:35:12 am
I believe Swift 3D version 3 and up have the transparency feature in the renderer. The materials tabs in the lower left-hand corner have transparency presets.
Just drag the material onto the object. You can then animate and on the keyframe change the object's transparency to fade in or out.
© 2018 All Rights Reserved
