Easing / Tweening questions...
COW Forums : Adobe Flash
Ken Ross
on Dec 20, 2005 at 7:13:45 pm
Okay, I downloaded the custom easing tool, and it is wonderful. However, I would like to replicate a few effects I have seen and can't quite get them without hand-making them. I've been trying since before I found this site, and it may simply be a job that has to be done manually, but I would much prefer to script it or find some other helpful plugin like the custom easing tool to do it!
First is an elastic box, where the center portions of the box are more elastic than the corners. The first example I saw of this was a templatemonster template, http://www.templatemonster.com/flash-templates/9728.html - in the opening animation the box expands from the loading bar to the picture frame. In the process, it has the elastic effect I would like to replicate.
Second is another effect I saw on template monster, a delayed/ghosted size tween. As the image scales up and slightly to the side, it has a ghost or two behind it which only show select frames, not the entire tween. The one I saw was http://www.templatemonster.com/flash-templates/7008.html.
As I mentioned, I *can* replicate both effects manually, and have done so - I would like to find out if there is a way to do either (or both) with actionscript instead of a frame by frame manual animation. Or, alternately, a plugin which can make that frame by frame for me.
