3D dice
COW Forums : Adobe Flash
graham quince
3D dice
on Dec 8, 2005 at 4:16:22 pm
Hi guys
I've built a 3D rolling dice game in Flash, but its a cheat. Basically, I had after effects produce an animation which i imported then had Flash swap in the last frame for a movieclip chosen at random from 1 to 6.
My problem is the file size from all those images and also you don't get to see the actual dice numbers roll into position. Does anyone here know how to use actionscript to create two 3D dice, which could have different faces. I've been asked to produce a set a word dice as well as number dice, and then have them roll to produce a random result?
Graham
http://www.qcit.com
Matt Klundt
Re: 3D dice
on Dec 14, 2005 at 1:55:53 am
I don't know of that in particular, but you may be able to use this class from macromedia to do it.
Matt
http://www.mcquillendesign.com
http://www.mattfoxgames.com
sher ali
Re: 3D dice
on Dec 14, 2005 at 1:15:34 pm
you should create six different aminations one
for each number on the dice and then play that
animation based on the random number generated.
Sher Ali,
InterActive Media Developer
