Blurred Edge Mask Effect
COW Forums : Adobe Flash
igadson
on Nov 29, 2005 at 9:50:52 pm
Does anyone know how to blur an edge of a mask??? I tried blurring the movie clip but it did not show up in the mask. Any help with this would be greatly appreciated.
Ian
iGADSON
DesignDime29
Re: Blurred Edge Mask Effect
on Dec 2, 2005 at 5:50:33 pm
Depends on what version you're using as to how easy it is! In Flash 8 it's as simple as converting two objects to movie symbols, naming the instances, then using a script like this;
maskedInstanceName.setMask(maskInstanceName);
pretty simple!
check out
http://www.macromedia.com/support/documentation/en/flash/fl8/samples.html
under Alpha Masking it has a simple zip.
IF USING ANOTHER VERSION OF FLASH-
couple ways to fake it
http://www.whatdoiknow.org/mt/mt-comments.cgi?entry_id=2407
under Phillip Kerman
Hope that helps
LeeBrimelow
on Dec 2, 2005 at 7:04:41 pm
One thing that Macromedia neglected to mention is that both MovieClips need to have "runtime bitmap caching" enabled in order for it to work.
