Flash Video Continous
COW Forums : Adobe Flash
Luis Nobrega
on Nov 22, 2005 at 12:25:35 am
Can anyone help me?
I've made the tutorial "7. Progressive Flash Video Player Part 2 - Additional component development" on this link:
and it was great! Congratulations Tiago Dias!
But i need something quite diferent. I want that the videos in XML file play continously without the combo box.
This code works with event change
var movList:Object = new Object ();
movList.change = function () { (cbMovie.getItemAt (cbMovie.selectedIndex).data);
pauseButton._visible = true;
playButton._visible = false;
cbMovie.addEventListener ("change", movList);
I try instead the complete event to go to the next video in the XML, but doesn't works..
var cmpVideo:Object = new Object ();
cmpVideo.complete = function () {
// in here i advance to next video
myVideo.addEventListener ("complete", cmpVideo);
myVideo is the name of the instance Video 1 that i created.
thanks in advance anyone!
Sher Ali
Re: Flash Video Continous
on Nov 22, 2005 at 9:39:53 am
you need to retrieve the next video from the list component
and pass it to method as;
if(cbMovie.getItemAt(cbMovie.selectedIndex+1) < cbMovie.length ){
cbMovie.selectedIndex = cbMovie.getItemAt(cbMovie.selectedIndex+1);;
cbMovie.selectedIndex = cbMovie.getItemAt(0).label);;
similarly you can retrieve the next video url from the xml object
and pass it to method.
Sher Ali,
Interactive Media Developer
Luis Nobrega
on Nov 22, 2005 at 11:02:54 am
Thanks for your answer!
But i don't want a combo box, i suppose that the problem is that i'm using not a FLVcomponent but a video, the complete doesn't work with the video object.
I'm afraid i have to use the FLVcomponent or can i use any heritage command to apply my video object??
thanks in advance
© 2018 All Rights Reserved
