Setting or Changing Stage Size at Run Time
COW Forums : Adobe Flash
lajoiet
on Nov 20, 2005 at 10:43:57 pm
OK, I'm thinking of making a flash file that basically would play an FLV file that the user selects at the bandwidth that the user selects, and controlled from an XML file for changing content. I can figure out how to resize the video holder and everything, but I can't seem to find anything about changing the size of the stage. Say for example I start out with my FLVs at 320x240, and design my stage with a bit of room around it like 400x300. Is there any way I can resize the stage and the video holder if I wanted to throw in a video at 720x480? I'd like to be able to give flash the stage size and the video file from the XML file and have it resize itself.
Thanks in advance
{and another thanks to Lee for all the video tutorial helps. I'm so proud of myself in that I figured out making a volume slider by using bits and pieces of your tutorials, and I think I'm finally begining to understand Functions, Intervals, and using empty movie clips to control things!!!!}
