FLV Playback Control
COW Forums : Adobe Flash
Bob Caligiuri
on Nov 15, 2005 at 12:48:06 am
I have a site using linked FLV files with Cue Points that trigger graphic displays. Thanks to Lee's help with the Listener code it works great. But now, the client wants more!
I need help with integrating a forward/rewind mechanism that will keep track of the cue points and graphic displays. When using the built in controller or other component-based video controls, it falls out of sync.
I assume I need to throw more Action Script at it. Can anyone assist with this? Here is a link to the current site:
Thanks again.. Bob
Re: FLV Playback Control
on Nov 16, 2005 at 7:16:01 pm
I looked at your presentation and I'm in the middle of making the exact same thing for a client. I'm having a hell of a time getting the cue points to trigger the graphic display. I looked in the forum for the listener code you talked about, but was unable to find any information on it. So I wanted to inquire if you could supply some info on how you got your presentation to work. Or at least point me in the direction towards the info on the listener code.
thanking you in advance
© 2018 All Rights Reserved
