Customizing New Shortcuts for Commands with Multiple Shortcuts
COW Forums : Maxon Cinema 4D
sean flores
on Apr 15, 2020 at 7:50:34 pm
Hello all.
I accidentally deleted the camera move shortcut ("1") and now I can't add it back in. It seems that any command with multiple shortcuts won't allow the additional of another shortcut.
Short of deleting the shortcut prefs, is there something I can do or something I'm missing?
Thanks in advance.
Brian Jones
Re: Customizing New Shortcuts for Commands with Multiple Shortcuts
on Apr 16, 2020 at 12:32:23 am
it should work if you select Move Camera, click on any of the shortcuts that are still there on the left but then change the Shortcut (which will read whatever you selected on the left) to 1 then hit Add.
