create small bubble splashes on the surface
COW Forums : Maxon Cinema 4D
Alexander Rohi-Bilverdy
on Jan 13, 2020 at 1:19:49 pm
Hello
I have a big pot where i will have it filled up with fluids.
Below i have a small fire going on, which is acting like boiling the soup/fluids inside the pot.
Now my question, how do i create the effect of small bubble splashes on the surface of the soup?? Hope this makes sense...
Looking forward to your answers
Br Hamid
marco nutella
Re: create small bubble splashes on the surface
on Jan 14, 2020 at 10:39:47 am
Hi, if you have x-particles, try to emit some from the bottom of the fluid, and then when reaching the top surface (via fallof), try to delete them with some tiny spawns that drive little splines, and give the splines some material, I think it could give the sense of popping bubbles.
Marc
on Jan 14, 2020 at 1:33:43 pm
Don’t have xparticles
John Williams
on Jan 20, 2020 at 10:35:44 am
Hi there, you could simply try having sphere's from an emitter rising up with a 'Collision deformer' on the surface. That will create dome deformations on the surface which then disappear when they go above the surface. If you then want more control on the secondary animation you could add a 'Jiggle deformer' so the surface wobbles a little after each bubble breaks through.
Hope that helps;)
John Williams
Soho Editors
