Glass with enclosed object too transparent
COW Forums : Maxon Cinema 4D
Achim Stromberger
on Nov 14, 2019 at 9:20:25 am
https://ibb.co/KVdDdsB
hi all, I need better contrast between the glass and the background. But if crank up the blurriness the object inside gets distorted.
Any hint on how to keep the object inside clearly visible, while making the whole glass object brighter in contrast to the background?
Thank You!
regards, A
Sam Treadway
Re: Glass with enclosed object too transparent
on Nov 15, 2019 at 1:21:33 am
Most of what you actually see in glass with a high transparency is reflections. Add a reflection map to the glass material...something as abstract as the scene and high contrast.
