SOFTBODIES & XPRESSO - Deforming a Mesh Using A Cloner
COW Forums : Maxon Cinema 4D
hayden martin
on Nov 13, 2019 at 1:56:19 pm
Hi
I'm trying to figure out the best way to connect the point's of an object to the points/index of a cloner to create fast softbody deformations with proxy geo
For example, imagine I have a sphere with clones attached to each vertex. If I set the dynamics to "Softbody Made of Clones", the clones fall with connections holding them together. How do I make these individual clone positions deform the mesh of the sphere?
I've attached a scene file which sort of does what I need, just not with a cloner sadly
Would massively appreciate any advice!
13884_6145iterationnulls2pointpos.c4d.zip
Sam Treadway
Re: SOFTBODIES & XPRESSO - Deforming a Mesh Using A Cloner
on Nov 14, 2019 at 5:55:31 am
If I understand correctly what you are attempting, then you will need two versions of the mesh.
One version that is static (and hidden) to use as the attachment object for the cloner and a copy that is 'morphed' by the clone positions using XPresso.
Here's a quick setup I made:
13892_deformmeshusingcloner.c4d.zip
hayden martin
on Nov 14, 2019 at 10:47:49 am
This is perfect!
Thanks Sam :)
