Ribbon unfolding, but with a twist
COW Forums : Maxon Cinema 4D
Joanna Goldman
on Oct 25, 2019 at 3:54:01 pm
Hi
I'm trying to get my ribbon to unfold, which I've pretty much got- but the final needs to look like this:
https://ibb.co/ygZ95V1
So far i have this:
https://ibb.co/vBsq70d
Any idea how to get the right side up a little and tilted?
This is my setup:
https://ibb.co/BV6gptW
Jim Scott
Re: Ribbon unfolding, but with a twist
on Oct 25, 2019 at 6:02:08 pm
Hi Joanna,
From your image it looks like the ribbon is lying on the XZ plane, and elongated along the X axis. If so, I think you just need to adjust the bend deformer's H rotation parameter. If the ribbon is oriented differently, try adjusting one of the other HPB parameters until you find the right one.
In fact, in your current setup it looks like you have already adjusted the proper parameter for the left bend deformer, so adjust the same one, probably in the opposite direction, for the right bend deformer. Hope this helps.
