Ease In to Linear (range mapping problem)
COW Forums : Maxon Cinema 4D
Corrado Carlevaro
on Jul 22, 2019 at 10:59:41 am
I want to write an Xpresso function to Ease In values at the beginning until normal linear interpolation, the very same way a car accelerates until it reaches constant speed, or the way you constraint 2 objects with a Spring Constraint.
Spline graph in Range Mapper doesn't work because at the end of spline mapping range there's always an angle.
In below picture I want to write an expression to get the blue curve from the green one (red one is range mapped)
Any ideas?
Corrado
