Alpha cut-out
COW Forums : Maxon Cinema 4D
mark madsen
Alpha cut-out
on Jan 3, 2018 at 7:47:47 pm
Hi all. I'm having a problem with a label on a bottle. I created the bottle and made a cylinder just larger in circumference for the label. The cylinder has a narrow break in it. I added a png to a material and applied it to the label. To round the edges, I added alpha and transparency and have tried a combination of both. No matter what I try, the edges of the cylinder are visible outside of the rounded corners of the png. Anyone have any suggestions?
Adam Trachtenberg
Re: Alpha cut-out
on Jan 3, 2018 at 9:23:35 pm
Can you upload the texture?
mark madsen
Re: Alpha cut-out
on Jan 3, 2018 at 10:24:35 pm
Actually I got a reply from another forum. I hadn't checked Evaluate Transparency in the render settings.
Adam Trachtenberg
Re: Alpha cut-out
on Jan 4, 2018 at 3:19:26 pm
Thanks for following up.
