Texture on two sides V-ray
COW Forums : Maxon Cinema 4D
Anderson Lipa
on Dec 17, 2016 at 6:49:27 pm
Guys, how do I fix the following problem ...
This box will have an impression on 2 sides so I made a UV mapping texture to the outside, duplicated it and added it to the interior, while using one of the standard Cinema 4d render engines I perfectly see the two interior and exterior textures.
Now comes the problem, when selecting the V-ray as render engine I only see the exterior texture reflecting on the inside.
Even converting the material to V-ray, the problem remains.
Any tips on how to fix this?
Thank you.
Adam Trachtenberg
Re: Texture on two sides V-ray
on Dec 22, 2016 at 3:45:10 pm
Use the Vray2SidedMaterial.
