Are render times affected by hidden objects
COW Forums : Maxon Cinema 4D
Chris Craig
on Sep 12, 2016 at 9:32:12 am
Hi guys
I have an model, with many small pieces inside of it. For the images that i am trying to create, these smaller objects are not needed. Will keeping them inside the larger object have any negative impact on render times?
Thanks a lot
Brian Jones
Re: Are render times affected by hidden objects
on Sep 13, 2016 at 6:09:21 pm
probably but I have no idea how much. It would have to decide if they are visible or not. In addition the help says C4D is optimized for fewer objects with (up to) millions of polys rather than millions of objects with few polys. You probably don't have enough objects inside for that to matter and the only way you can really tell is to do a couple comparison renders one with the objects, one without.
